The Tormek T-4 Black is a special edition of the Tormek T-4 Original, featuring an all-black housing, the new SH-200 Hybrid Graystone, exclusive to the T-4 Black, and the CW-145 Composite Honing Wheel. With its all-black look, the Tormek T-4 Black has a bold, distinctive, sleek appearance that looks great in any garage or workshop.
The Tormek T-4 is an incarnation within a long line of Tormek water-cooled grinding systems and incorporates, innovative, patented features that allows you to sharpen your tools to the finest edge. Sharpen plane irons, chisels, hand tools, knives, scissors, woodturning and woodcarving tools with ease. Firstly, the zinc cast top incorporates the key components of the main shaft, Universal Support and motor assembly resulting in superb accuracy as standard. Secondly, the Universal Support is held in two sleeves in the zinc cast top, meaning that the improved locking design and tighter tolerances will give even better results. Both designs give improved accuracy and precision for easy sharpening on the Tormek T-4. The water-cooled system helps maintain the temper of the steel, and this combined with the 120 rpm slow speed sharpens tools precisely, while preventing the tool from overheating.
The SH-200 Hybrid Graystone combines aluminum oxide and silicon carbide abrasives, bringing together qualities from the Original Grindstone and the Blackstone Silicon. The 200mm grinding wheel delivers efficient sharpening with a fine surface finish across a wide range of materials – from tool steels and HSS to carbide and ceramics. Its surface can be graded with the SP-650 Stone Grader (sold separately) for an even finer finish, delivering characteristics equivalent to between 220 and 1,000 grit. The TT-50 Truing Tool (sold separately) can be used to restore the grinding wheel to a flat, true surface.
The included CW-145 Composite Honing Wheel deburrs edges after sharpening and can also be used for regular edge maintenance. It provides a quick way to hone your tools and regain sharpness when a new bevel is not needed. No honing compound is needed thanks to the integrated polish.
The T-4 uses a powerful, maintenance-free, industrial AC motor and the shaft supporting the wheels is made from corrosion resistant stainless steel. The main shaft features Tormek's EzyLock mounting system for fast stone changes without a spanner.
Compatible with a wide range of sharpening jigs, the Tormek system offers an extensive selection of jigs and accessories, allowing you to configure the machine to suit a variety of sharpening requirements.
For more tips on sharpening please see Tormek's YouTube channel.
Please note, this machine is 230V.
8-year warranty* (5 + 3) 5 years + 3 years when you register at tormek.com
*The warranty is 2 years when used for commercial, industrial, or educational purposes
