{"product_id":"tormek-t-4-black-230v","title":"Tormek T-4 Black Sharpening System","description":"\u003cdiv class=\"OutlineElement Ltr SCXW66253008 BCX8\"\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eThe \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e T-4 Black is a special edition of the \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e T-4 Original, featuring an all-black housing, the new SH-200 Hybrid Graystone\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e, exclusive to the T-4 Black,\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e and the CW-145 Composite Honing Wheel.\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eWith its all-black look, the \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e T-4 Black has a bold, distinctive\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e, sleek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e appearance that \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003elooks great in any garage or workshop. \u003c\/span\u003e\u003c\/span\u003e\u003cspan class=\"EOP Selected SCXW66253008 BCX8\" data-ccp-props=\"{}\"\u003e \u003c\/span\u003e\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"OutlineElement Ltr SCXW66253008 BCX8\"\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eThe \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e T-4\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e is an incarnation within \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003ea long line\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e of \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e water-cooled grinding systems and\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e incorporates, innovative, patented features that allows you to sharpen your tools to the finest edge. \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eSharpen plane irons, chisels, hand tools, knives, scissors, \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003ewoodturning\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e and woodcarving tools with ease. \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eFirstly, the zinc cast top incorporates the key components of the main shaft, Universal Support and motor assembly resulting in superb accuracy as standard. Secondly, the Universal Support is held in two sleeves in the zinc cast top, meaning that the improved locking design and tighter tolerances will give even better results. Both designs give improved accuracy and precision for easy sharpening on the \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e T-4.\u003c\/span\u003e\u003c\/span\u003e\u003cspan class=\"EOP Selected SCXW66253008 BCX8\" data-ccp-props=\"{}\"\u003e The water-cooled system helps maintain the temper of the steel, and this combined with the 120 rpm slow speed sharpens tools precisely, while preventing the tool from overheating. \u003c\/span\u003e\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"OutlineElement Ltr SCXW66253008 BCX8\"\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eThe SH-200 Hybrid Graystone combines \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003ealuminum\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e oxide and silicon carbide abrasives, bringing together qualities from the Original Grindstone and the Blackstone Silicon. The 200mm grinding wheel delivers efficient sharpening with a fine surface finish across a wide range of materials – from tool steels and HSS to carbide and ceramics. Its surface can be graded with the SP-650 Stone Grader (sold separately) for an even finer finish, delivering characteristics equivalent to between 220 and 1\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e,\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e000 grit. The TT-50 Truing Tool (sold separately) can be used to restore the grinding wheel to a flat, true surface.\u003c\/span\u003e\u003c\/span\u003e\u003cspan class=\"EOP Selected SCXW66253008 BCX8\" data-ccp-props=\"{}\"\u003e \u003c\/span\u003e\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"OutlineElement Ltr SCXW66253008 BCX8\"\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eT\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003ehe included CW-145 Composite Honing Wheel deburrs edges after sharpening and can also be used for regular edge maintenance. It \u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eprovides\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e a quick way to hone your tools and regain sharpness when a new bevel is not needed. No honing compound is needed thanks to the integrated polish. \u003c\/span\u003e\u003c\/span\u003e\u003cspan class=\"EOP Selected SCXW66253008 BCX8\" data-ccp-props=\"{}\"\u003e \u003c\/span\u003e\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"OutlineElement Ltr SCXW66253008 BCX8\"\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eThe T-4 uses a powerful, maintenance-free, industrial AC motor and the shaft supporting the wheels is made from corrosion resistant stainless steel. \u003c\/span\u003e\u003cspan class=\"NormalTextRun CommentStart SCXW66253008 BCX8\"\u003eThe main shaft features Tormek's\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eEzyLock\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e mounting system for fast stone changes without a spanner.\u003c\/span\u003e\u003c\/span\u003e\u003cspan class=\"EOP Selected SCXW66253008 BCX8\" data-ccp-props=\"{}\"\u003e \u003c\/span\u003e\u003c\/p\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003eCompatible with a wide range of sharpening jigs, the Tormek system offers an extensive selection of jigs and accessories, allowing you to configure the machine to suit a variety of sharpening requirements.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"OutlineElement Ltr SCXW66253008 BCX8\"\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003eFor more tips on sharpening please see \u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003eTormek\u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003e'\u003c\/span\u003e\u003cspan class=\"NormalTextRun SpellingErrorV2Themed SCXW66253008 BCX8\"\u003es\u003c\/span\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e YouTube channel.\u003c\/span\u003e\u003c\/span\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003ePlease note, this machine is 230V. \u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e\u003cspan\u003e8-year warranty* (5 + 3) 5 years + 3 years when you register at tormek.com\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp class=\"Paragraph SCXW66253008 BCX8\"\u003e\u003cspan data-contrast=\"auto\" lang=\"EN-GB\" class=\"TextRun SCXW66253008 BCX8\"\u003e\u003cspan class=\"NormalTextRun SCXW66253008 BCX8\"\u003e\u003cspan\u003e*The warranty is 2 years when used for commercial, industrial, or educational purposes\u003c\/span\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Tormek","offers":[{"title":"Default Title","offer_id":55287745282395,"sku":"115183","price":485.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/115183_xl.jpg?v=1795520063","url":"https:\/\/www.axminstertools.com\/products\/tormek-t-4-black-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
