You'll have better control when sharpening turning tools and carving tools if the stone is turning away from the cutting edge. By adding the Tormek Horizontal Base to your older Tormek you can move the Universal Support from vertical mount (wheel turning into edge) to horizontal mount (wheel turning away from edge). The Owner's Handbook gives you recommended mounts for various tools and jigs. Includes all necessary mounting hardware. This base is now standard on the latest Tormek.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485002185
