The TRACER Pro Deep Hole Construction Pencil is not your average builder's marking pencil. It's designed for accurate marking in locations that are otherwise impossible to reach, whilst withstanding demanding use in harsh jobsite conditions. The Pro Deep Hole Pencil can reach up to 100mm deep through a 3mm hole and up to 145mm deep through a 6mm hole - this make it ideal for marking through fixing holes, recessed surfaces and hard-to-access areas commonly encountered in construction, installation and joinery work. Capable of marking on wood, metal, plastic, ceramics and other building materials, it's a premium solution for those needing a professional marking pencil.
The complete TRACER Pro Deep Hole Construction Pencil Kit includes the Pro Series Deep Hole Pencil, which is engineered with a durable aluminium body and an anti-roll design to keep the pencil close at hand when working on site. Also included is a TRACER site holster with integrated sharpener to maintain a fine point for accurate marking, six 2B graphite replacement leads and a TRACER anti-snap lead dispenser for secure storage and easy lead replacement
TRACER is a specialist manufacturer of professional marking and measuring tools trusted by tradespeople across the construction industry. They are known for innovative deep hole marking solutions and practical jobsite-focused designs, and the TRACER Pro Series Deep Hole Construction Pencil Kit is a perfect example of a reliable marking system for everyday trade applications and demanding jobsite conditions.
Web Attribute Set Marking Pencils
EAN Barcode 5060668273746
