The TRACER ProContour Gauge is a professional profile marking and scribing tool. With it, it's possible to accurately copy and transfer complex shapes onto flooring, skirting boards, pipework, worktops and other surfaces. Available in 130mm and 250mm sizes, this heavy-duty contour gauge enables users to quickly capture irregular profiles and replicate them onto materials for precise cutting and fitting. The lockable mechanism securely holds the profile shape in place, helping to improve accuracy and reduce material waste during installation and finishing work. The contour gauge features metric and imperial measuring scales for added convenience on site.
The TRACER ProContour Gauge range is available in two sizes to suit different applications. The 130mm model is ideal for everyday profile marking tasks and is useful for tighter spaces, while the larger 250mm version is capable of handling wider profiles and larger projects. Both models feature durable construction designed for regular trade use and provide a simple, reliable solution for flooring installation, carpentry, joinery, plumbing and general construction work. The 250mm version also includes a TRACER Deep Hole Construction Pencil, providing a complete marking and scribing solution straight out of the box.
TRACER is a leading manufacturer of professional marking and measuring tools for the construction industry. Known for practical innovation and jobsite-ready durability, the brand develops tools that help tradespeople improve accuracy, efficiency and confidence across a wide range of applications.
Length 130 mm
Web Attribute Set Miscellaneous Gauges
EAN Barcode 5060668272640
