Trendiwax is a solid wax lubricant extends the life of the blades and drill bits by reducing the heat build-up at the cutting edges and points, suitable for cutting steel, aluminium and other non-ferrous metals. It is applied directly to the teeth of a stationary blade or drill bit tip. Comes in a 343g tube.
Web Attribute Set Lubricants & Cleaners
EAN Barcode 5027654504789
