{"product_id":"tso-power-loc-bench-connector-dog","title":"TSO Power-Loc Bench Connector Dog","description":"\u003cp\u003eThe TSO Power-Loc Bench Connector Dog is a 20mm diameter clamping device designed for use on multifunction workbenches, Festool MFT and Parf\/ UJK workstations. These Bench Connector Dogs are compatible with most grid tables with chamfered 20mm holes.\u003c\/p\u003e\u003cp\u003eThey function as a unique and secure method of attaching an extension to a your grid worktop or adding a jig, fixture or other accessory mounted on a board. The Power-Loc Bench Connector Dog locks two boards together quickly, safely and very securely.\u003c\/p\u003e\u003cp\u003eThe Power-Loc Dog uses an offset cam and integrated locking lug design. They provide precision registration and alignment and apply strong clamping pressure. The design eliminates the need to use a separate clamp or locking knob from the underside of the worktop. The Power-Loc is tightened from the top with a 5mm hex driver making them ideal for those benches with no access to the underside. The chamfered lip means the Power-Loc Dog sits nicely flush with the work surface without taking up valuable space on your worktop.\u003c\/p\u003e\u003cp\u003ePrecision made from  300 series stainless steel. They have a clamping range of 30mm (1-3\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) to 40mm (1-9\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e), weight: 92g.\u003c\/p\u003e","brand":"TSO Products","offers":[{"title":"Default Title","offer_id":54118443155803,"sku":"108177","price":55.88,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/108177_xl.jpg?v=1789780310","url":"https:\/\/www.axminstertools.com\/products\/tso-power-loc-bench-connector-dog","provider":"Axminster Tools","version":"1.0","type":"link"}
