{"product_id":"tso-products-grs-16-pe-v2-parallel-edge-guide-rail-adaptor","title":"TSO Products GRS-16 PE v2 Parallel Edge Guide Rail Adaptor","description":"\u003cp\u003eThis GRS-16 PE v2 parallel Edge Guide Rail square fits onto either Festool, Makita or Milwaukee guide rails. Made from solid aluminium, CNC machining ensures extreme accuracy and allows you to achieve dead square cuts with your Festool, Makita or the Milwaukee M 18 fuel track saw. By dropping onto the guide rail instead of sliding from either side, you can attach it to your guide rail faster and more simply. Once you've secured it into the T-slot of your guide rail and closed the latch, you are good to go.\u003c\/p\u003e\u003cp\u003eThe GRS-16PE guide rail square features two reference edges. The advantage of this feature is it allows you to reference using either the front or back edge of the workpiece depending on the situation. For instance, when cutting kitchen worktop, you can use the rear square edge rather than the rolled front edge to guarantee an accurate result. The ability to reference either the front or back edge gives you flexibility as to the direction of your cut. As in most cases, it is better to have your workpiece underneath the guide rail and the waste on the opposite side. The 400mm long reference edges are at precisely 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to your track. There is a small notch in the front of each reference edge to allow you to use a guide rail clamp for extra security should you so wish. The extra fitting holes are taped and drilled ready to attach the Festool MFT hinged bracket.\u003c\/p\u003e","brand":"TSO Products","offers":[{"title":"Default Title","offer_id":54118495813979,"sku":"109810","price":139.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109810_xl.jpg?v=1789782651","url":"https:\/\/www.axminstertools.com\/products\/tso-products-grs-16-pe-v2-parallel-edge-guide-rail-adaptor","provider":"Axminster Tools","version":"1.0","type":"link"}
