{"product_id":"tso-triangle-to-guide-rail-adapter-61-525","title":"TSO Triangle to Guide Rail Adapter 61-525","description":"\u003cp\u003eThe TSO Triangle to Guide Rail adaptor is an accessory that transforms precision triangles into large, variable angle guide rail squares. If you own a MTR-18 or PTR-18 TSO precision triangle, the adaptor allows you to connect it to guide rails made by Festool, Makita, Milwaukee, Kreg, WEN, RIDGID and Powertec.\u003c\/p\u003e\u003cp\u003eSimply attach the adaptor to your triangle using the tapped accessory mounting holes. Loosen the two hex screws so the torpedo nut can be slid into the T-slot and slide onto your guide rail's top-mounted T-track. Position at your desired point and secure using the hex screws.\u003c\/p\u003e\u003cp\u003eSupplied with triangle adaptor, torpedo nut with keystone alignment feature, x2 M6 x 1.0 hex screws, x2 M5 x 0.8 flathead socket cap screws.\u003c\/p\u003e","brand":"TSO Products","offers":[{"title":"Default Title","offer_id":54118506299739,"sku":"110978","price":52.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/110978_xl.jpg?v=1789783609","url":"https:\/\/www.axminstertools.com\/products\/tso-triangle-to-guide-rail-adapter-61-525","provider":"Axminster Tools","version":"1.0","type":"link"}
