A very popular classic writing instrument, in a nickel satin finish, with a standard twist mechanism. If a mandrel is used to make these pens no bushings are necessary and a 7mm drill will be required. We recommend the Fisch pen drill (502103) which is available in this size. For ink refills order 310492.
Pen Kit Classification Scholar
Difficulty Beginner
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 16 mm x 16 mm x 112 mm
Pen Type Twist Pen
Finish Nickel
Refill Order Number 310492
Colour Nickel Web Attribute Set: Project Kits
EAN Barcode 5052511028726
