{"product_id":"ujk-10mm-aluminium-router-table-insert","title":"UJK 10mm Aluminium Router Table Insert","description":"\u003cp\u003eThis 10mm aluminium insert plate for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing. The insert plate will accommodate most portable routers and should be drilled to individual requirements.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118343999835,"sku":"105932","price":125.58,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105932_xl.jpg?v=1789776689","url":"https:\/\/www.axminstertools.com\/products\/ujk-10mm-aluminium-router-table-insert","provider":"Axminster Tools","version":"1.0","type":"link"}
