UJK
UJK 10mm Aluminium Router Table Insert
SKU: 105932
£125.58
£104.65 Excl. VAT
  • UJK 10mm aluminium router table insert plate
  • Threaded lead-in pin
  • To fit 230 x 306mm aperture
  • Twist lock insert ring supplied with wrench
  • Range of central insert rings available
This 10mm aluminium insert plate for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. It is supplied with a removable central insert ring with a 38mm diameter hole with a range of other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing. The insert plate will accommodate most portable routers and should be drilled to individual requirements.
Web Attribute Set Router Table Accessories
EAN Barcode 5052511116362
