These simple split stop collars add another level of usefulness to your bench dogs. Each collar has a 38mm outer diameter and 20mm inner bore. They slide over your bench dogs forming a temporary hold down. They are particularly useful for instance when biscuit or DOMINO jointing boards. The rear of the board butts up against the bench dogs with split collars preventing the boards from lifting. The split design will not mark or create burrs on the bench dog.
Supplied in a pack of two including hex wrench.
Intended Use Used in conjunction with dog holes to hold work to a workbench.
EAN Barcode 5052511119417
