{"product_id":"ujk-air-wedge-wide-260mm","title":"UJK Air Wedge - Wide 260mm","description":"\u003cp\u003eThe UJK Air Wedge uses the same principle that air-jacks use to lift large commercial vehicles weighing many tons.\u003c\/p\u003e\u003cp\u003eVersatile doesn’t even begin to describe the UJK Air Wedge. Whether you are fitting, fixing or levelling, the UJK Air Wedge makes the job a great deal easier. The UJK Air Wedge is good for lifting something up, pushing something into position or forcing things apart. Made from highly durable, non-marring material and with triple welded seams, the UJK Air Wedge is virtually indestructible. An internal stiffener makes it easy to insert the UJK Air Wedge into a narrow gap. By gently squeezing the bulb, you can make controlled, fine adjustments. Press the release valve to deflate the Air Wedge.\u003c\/p\u003e\u003cp\u003eInitially marketed as a tool for holding window frames in place prior to fixing, it is indispensable in many other situations. When fitting a door, a UJK Air Wedge underneath one corner makes it easy to align the hinges. For levelling kitchen appliances or cabinets, use a UJK Air Wedge to lift a fridge or washing machine etc while you make adjustments.\u003c\/p\u003e\u003cp\u003eWide: size 260mm x 145mm, lift 2mm to 85mm, maximum lifting weight 180kg.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118307856731,"sku":"104998","price":17.28,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104998_xl.jpg?v=1789774808","url":"https:\/\/www.axminstertools.com\/products\/ujk-air-wedge-wide-260mm","provider":"Axminster Tools","version":"1.0","type":"link"}
