Supplied in packs of two, the UJK Cam Lock Hold Down Clamp offers ultra fast lock and quick release for all manner of fixtures and fences. They are easy to use, self-locking and exert plenty of force. The M8 x 75mm, T-bolt is compatible with the UJK T-Track. Obviously, by substituting the T-bolt for a regular M8 bolt you have the option of using the Cam Lock wherever you wish.
Screw the lever down until it is touching the top of the fixture / fence etc. Pushing the end of the lever down, applies considerable clamping force. To release the fixture, simply lift the lever.
Each pack contains two anodised aluminium cam levers, two threaded cross dowels, aluminium stepped track adaptor and nylon and steel washers.
EAN Barcode 5052511117291
