{"product_id":"ujk-cam-wedge-clamping-set","title":"UJK Cam \u0026 Wedge Clamping Set","description":"\u003cp\u003eThe UJK Cam \u0026amp; Wedge set is an exceptionally useful accessory for a multifunction table. It allows you to clamp a workpiece leaving its top free from any obstruction for routing, sanding, carving etc. The principle is as old as the pyramids and just as effective now as it was then. The UJK Cam \u0026amp; Wedge set offers complete unbudgeability.\u003c\/p\u003e\u003cp\u003eThe set comprises three stainless steel 12mm guide pups, a surface cam clamp and CNC machined HDF Valchromat, backstop, two wedges and spacer block. The backstop has three dog holes; two spaced at 96mm for lateral or longitudinal positioning and the third for diagonal placement.\u003c\/p\u003e\u003cp\u003eThe surface cam clamp also features screw holes allowing its use on a plain board. Depending on the width or thickness of your workpiece, you may need to use one or both wedges and possibly the spacer block. All parts are available separately.\u003c\/p\u003e\u003cp\u003eValchromat is certified by the Pan European Forest Council (PEFC).\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118324044123,"sku":"105369","price":39.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105369_xl.jpg?v=1789775590","url":"https:\/\/www.axminstertools.com\/products\/ujk-cam-wedge-clamping-set","provider":"Axminster Tools","version":"1.0","type":"link"}
