{"product_id":"ujk-chamfer-tool","title":"UJK Chamfer Tool","description":"\u003cp\u003eThis specially designed tool cuts a neat, small chamfer around the precise 20mm dog hole made by the UJK 20mm cutter, as part of using the UJK Parf Guide System. You can also use it on the Festool MFT\/3 table or any custom cutting table made using the UJK Parf Guide System. A shallow chamfer has two benefits. Its primary advantage is it allows full use of the UJK Super Dog, when fitted with its stop collar. Secondly, by removing the sharp edge around the hole, it prevents damage from repeated insertion of dogs, clamps and other accessories.\u003c\/p\u003e\u003cp\u003eThe UJK Chamfer Tool has a solid tungsten carbide cutter with four cutting edges. If the edge becomes dull, turn the cutter 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to a fresh edge; in all probability it will never need replacing. Only suitable for use with MDF or ply with a melamine facing.\u003c\/p\u003e\u003cp\u003ePlease note that the UJK Multifunction Workbench has chamfered dog holes as standard.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118296977755,"sku":"104464","price":14.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104464_xl.jpg?v=1789774235","url":"https:\/\/www.axminstertools.com\/products\/ujk-chamfer-tool","provider":"Axminster Tools","version":"1.0","type":"link"}
