UJK
UJK Compact Cast Iron Router Table Top
SKU: 502532
£198.98 £308.48 Save £109.50
£165.82 Excl. VAT
  • UJK Compact Cast Iron Router Table Top
  • Designed to accept UJK leg stand and fence
  • Top measures 686 x 406 x 40mm
  • Range of insert options available
  • Dust collection box available
The UJK Compact Cast Iron Router Table Top is one of a range of options that you can choose from when making up your UJK router table. Simply add the leg stand, fence and required insert and you will have a very sturdy versatile unit capable of many routing operations. The benefits of using cast iron for the manufacture of machine tables are well known especially where vibration damping and stability are paramount. The quality of the surface grinding on this 686 x 406 x 40mm top is superb, offering little resistance when passing stock across the table during use. A standard 19mm wide slot is incorporated for the use of a mitre fence attachment and a T-slot is also present for jigs and accessories. The top is threaded to accept the UJK compact leg stand, fence assembly and optional dust collection box. The 230 x 306mm central aperture will accept the router elevator and other available UJK insert options.
Web Attribute Set Router Table Accessories
EAN Barcode 5052511054657
