Routing a hinge or lock plate recess always leaves you with rounded corners. You could square off the corners with a normal chisel. However, the UJK Corner chisel is much quicker and highly accurate. Clean, perfectly square corners give the job a professional, clean looking finish.
The blade is tungsten steel, sharpened to a perfect 90
