{"product_id":"ujk-corner-chisel","title":"UJK Corner Chisel","description":"\u003cp\u003eRouting a hinge or lock plate recess always leaves you with rounded corners. You could square off the corners with a normal chisel. However, the UJK Corner chisel is much quicker and highly accurate. Clean, perfectly square corners give the job a professional, clean looking finish.\u003c\/p\u003e\u003cp\u003eThe blade is tungsten steel, sharpened to a perfect 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e corner. The steel body has locating lugs, which automatically align the chisel. A sharp tap with a hammer and the spring loaded chisel cleanly cuts the corner.  Pare away the little piece of waste for a perfect cut every time.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118280266075,"sku":"103864","price":15.28,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103864_xl.jpg?v=1789773446","url":"https:\/\/www.axminstertools.com\/products\/ujk-corner-chisel","provider":"Axminster Tools","version":"1.0","type":"link"}
