The UJK Hex Shank Adaptor Drill Kit combines two of the UJK’s finest drilling solutions together: the UJK Hex Shank Drill Bit Adaptor and the UJK StepPower HSCO Drill Bits. Together, they give you the speed and convenience of quick-change adaptors, and the durability and cutting power of cobalt drill bits for metal or hardwood. Whether you’re working in timber, engineered boards, acrylics, or metal, this kit ensures you always have the right bit ready to deliver accurate, efficient results.
Transform your standard round shank drill bits, burrs, and abrasive points into quick-change hex shank tools with the UJK Hex Shank Drill Bit Adaptor. Compatible with standard 1/4 hex and Festool CENTROTEC systems, these stainless steel adaptors are engineered to ultra-high tolerances for a secure fit and minimal runout. Available in multiple sizes (2–10mm), they offer a cost-effective alternative to dedicated hex shank bits while maintaining precision and flexibility.
Engineered for performance, the UJK StepPower HSCO Drill Bits are crafted from 5% cobalt high-speed steel for maximum wear resistance and durability. Their unique multi-step design, combined with a 118° point geometry, ensures perfect centring, clean entry, and reduced splintering. While primarily designed for metalworking, their sharpness and precision make them equally effective in hardwoods. A 3-flat shank prevents slipping in the chuck, guaranteeing accuracy and efficiency whether you’re drilling in metal, wood, or both.
Drill Bit Diameter 2.0 mm
Web Attribute Set Drill Bit Sets
EAN Barcode 5052511144198
