The UJK HSS Countersink & Premium HSS M2 Drill Bits from Austria are high-quality tools made for precise and efficient performance.
This HSS Drill and countersink set is suitable for use in wood in both power tools and drill presses, making it ideal for various applications and setups. The design ensures clean cutting and efficient chip removal, resulting in smooth and precise holes every time
Manufactured in Austria from premium high-speed steel (HSS), the countersink and drill bits are built to last, providing durability and longevity even with frequent use. The HSS material ensures that the cutting edges remain sharp, allowing for clean, accurate drilling and countersinking in a variety of materials, including softwood and hardwood.
The UJK HSS Countersink & Premium HSS Drill Bits offer the advantages of exceptional design, accuracy, and efficiency.
Drill Bit Diameter 6.0 mm
Intended Use Designed to create a conical hole that accommodates the head of a screw.
EAN Barcode 5052511137541
