{"product_id":"ujk-long-super-dog","title":"UJK Long Super Dog","description":"\u003cp\u003eThe majority of plunge saws can cut between 40 and 65mm deep. However, when used with a guide track and standard bench dogs on a multifunction workbench, the setup is generally limited to cutting sheet material. The UJK Long Super Dog removes this limitation, opening a completely new range of joinery and carpentry possibilities.\u003c\/p\u003e\u003cp\u003eThe 120mm projection allows you to cut much thicker timber, taking full advantage of your saw’s depth of cut. Using your multifunction workbench and track, the Long Super Dog offers exacting precision for cutting large timbers or trenching.\u003c\/p\u003e\u003cp\u003ePrecise CNC manufacturing from 303 stainless steel to exceptionally fine tolerances ensures precision and a lifetime of accuracy.\u003c\/p\u003e\u003cp\u003eLong Super Dogs fit exactly into the 20mm holes of the UJK multifunction workbench. They are compatible with the Festool MFT\/3 and self-built grid tables made using UJK Parf Guide System. Push the Long Super Dog into a hole, simply twist the top and it’s rock solid.\u003c\/p\u003e\u003cp\u003eThe Long Super Dog has a 120mm projection and comes with 2 interchangeable collars. A 10mm tall register collar with a 25mm diameter exactly mimics the original bench dog. The Stop collar fits into a chamfer around the dog hole (standard on the UJK workbenches). This provides a register ensuring the dog sits flush and perpendicular to the work surface.\u003c\/p\u003e\u003cp\u003eA UJK chamfer cutter is available for non-chamfered tables. We recommend using the Dog Rail Clip with the Long Super Dogs. A standard UJK Super Dog is also available.\u003c\/p\u003e\u003cp\u003eThe UJK Chamfer Ring© is the intellectual property of Axminster Tools Ltd. Any infringement is strictly prohibited.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118303301979,"sku":"104719","price":24.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104719_xl.jpg?v=1789774543","url":"https:\/\/www.axminstertools.com\/products\/ujk-long-super-dog","provider":"Axminster Tools","version":"1.0","type":"link"}
