UJK
UJK Loose Tenon Router Cutters - 1/2" Shank
SKU: 112102
€55,00
  • Make your own Festool Domino-style biscuits
  • Make your own Hardwood Festool Domino-style biscuits
  • Ideal for exterior loose tenons
  • Cut any length biscuit
  • Suitable for all types of wood
  • British made UJK Loose Tenon Cutter
  • Available in 1/2 and 12mm shank sizes, with three cutter sizes each covering 3-4 biscuit sizes, covering all sizes of Festool Dominos
  • Xylan coated minimising friction and resin build-up and enhances chip flow
  • Manufactured from EN8 Steel for strength and durability
The UJK Loose Tenon Cutters, is a game-changer for woodworkers. This innovative router cutter allows you to cut Domino-style biscuits, offering unparalleled flexibility and creativity in your projects.
Craft perfect fitting Domino-style biscuits from hardwood, softwood, or even off-cuts from your workshop to either match or contrast with your project. One of the major advantages is that you can create hardwood Festool-style Domino's, ideal for exterior work, your outdoor projects can be solid, secure and hardy to the elements.
Available in both 1/2 and 12mm shank sizes, with two different cutter sizes, the smaller cutter produces 4, 5, 6, and 8mm biscuits, while the larger cutter makes 10, 12, and 14mm biscuits. Both cutters offer the flexibility to cut any length you need, and all UJK Loose Tenon Cutters cover all sizes of Festool Domino's, saving you money on buying packs of Dominos or multiple tenon cutters.
As the UJK Router Cutter range grows, all UJK cutters are proudly made in Britain. Manufactured from EN8 steel and coated with Xylan to reduce friction and enhance chip flow, prevents build-up, and extend the cutters lifespan. These strong, durable cutters feature a reinforced shank radius, enhancing their strength further for tough tasks.
Designed specifically for use with router tables, the UJK Loose Tenon Cutter are ideal for both professional and hobbyist woodworkers.
Upgrade your woodworking toolkit with the UJK Loose Tenon Cutter and enjoy the freedom to create custom Domino-style biscuits from any wood you choose. This high-quality, British-made tool is a must-have for anyone serious about joinery.
Shank Diameter 1/2" (12.7 mm)
Dowel Size 4, 5, 6, 8 mm
Intended Use Used to produce your own Domino-style biscuits.
EAN Barcode 5052511138098
