{"product_id":"ujk-loose-tenon-router-cutters-12mm-shank","title":"UJK Loose Tenon Router Cutters - 12mm Shank","description":"\u003cp\u003eThe UJK Loose Tenon Cutters, is a game-changer for woodworkers. This innovative router cutter allows you to cut Domino-style biscuits, offering unparalleled flexibility and creativity in your projects.\u003c\/p\u003e\u003cp\u003eCraft perfect fitting Domino-style biscuits from hardwood, softwood, or even off-cuts from your workshop to either match or contrast with your project. One of the major advantages is that you can create hardwood Festool-style Domino's, ideal for exterior work, your outdoor projects can be solid, secure and hardy to the elements.\u003c\/p\u003e\u003cp\u003eAvailable in both 1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e and 12mm shank sizes, with two different cutter sizes, the smaller cutter produces 4, 5, 6, and 8mm biscuits, while the larger cutter makes 10, 12, and 14mm biscuits. Both cutters offer the flexibility to cut any length you need, and all UJK Loose Tenon Cutters cover all sizes of Festool Domino's, saving you money on buying packs of Dominos or multiple tenon cutters.\u003c\/p\u003e\u003cp\u003eAs the UJK Router Cutter range grows, all UJK cutters are proudly made in Britain. Manufactured from EN8 steel and coated with Xylan to reduce friction and enhance chip flow, prevents build-up, and extend the cutters lifespan. These strong, durable cutters feature a reinforced shank radius, enhancing their strength further for tough tasks\u003c\/p\u003e\u003cp\u003eDesigned specifically for use with router tables, the UJK Loose Tenon Cutter are ideal for both professional and hobbyist woodworkers.\u003c\/p\u003e\u003cp\u003eUpgrade your woodworking toolkit with the UJK Loose Tenon Cutter and enjoy the freedom to create custom Domino-style biscuits from any wood you choose. This high-quality, British-made tool is a must-have for anyone serious about joinery.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"4, 5, 6, 8 mm","offer_id":54165132968283,"sku":"112101","price":49.98,"currency_code":"GBP","in_stock":true},{"title":"10, 12, 14 mm","offer_id":54165133001051,"sku":"112103","price":49.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/112104_xl.jpg?v=1792571774","url":"https:\/\/www.axminstertools.com\/products\/ujk-loose-tenon-router-cutters-12mm-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
