Part of the trusted UJK Parf accessory range, these UJK Low Profile Dogs are a clever solution for reliable workholding on a 20mm hole bench. Whether you’re using a custom made top with a 20mm grid, a UJK worktop, or Festool MFT table, they’ll keep your workpiece exactly where you want it without getting in the way.
Their low height makes them ideal for jobs where standard bench dogs can be intrusive, perfect for sanding, planing, or working with thinner workpieces. Precision machined from anodised aluminium, the UJK Low Profile Dogs are tough, lightweight, and resistant to corrosion.
The flat-faced dogs offer a broader contact area, giving you extra grip and stability for fine, accurate work, supplied as a pair and have a 12mm projection above the surface of your bench and will quickly become a go-to for countless projects.
