{"product_id":"ujk-machine-aligning-jig","title":"UJK Machine Aligning Jig","description":"\u003cp\u003eIt is important to get the best from your saw, an accurate set up guarantees accurate results. The UJK Aligning Jig is a highly accurate jig that is simple to use. On a table saw you can measure:\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e The alignment of the blade to the mitre slots\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e The alignment the fence to the mitre slots\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e The axial run-out of the blade (the side to side wobble you see if the blade is turned slowly)\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e The axial run out of the blade flange\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e The axial run out of the blade arbor\u003c\/p\u003e\u003cp\u003eBased on a simple mounting bar that fits any standard 19mm (3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) mitre gauge slot, the mounting bar has adjustable spring loaded balls to ensure a snug fit, plus levelling screws to accommodate differing depths of mitre slot. This metric versions dial indicator reads in increments of 0.01mm with a total travel of 10mm. An invaluable tool in any workshop.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54117904875867,"sku":"108326","price":77.88,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/108326_xl.jpg?v=1789769775","url":"https:\/\/www.axminstertools.com\/products\/ujk-machine-aligning-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
