{"product_id":"ujk-mitre-slot-track","title":"UJK Mitre Slot Track","description":"\u003cp\u003eThe UJK mitre slot track makes it easy to add a mitre fence facility to a custom built router table, saw table or bandsaw table. It is equally useful for a workbench that needs to incorporate a mitre fence.\u003c\/p\u003e\u003cp\u003eThe track is anodised aluminium for its durability. All it requires is a routed groove 31mm wide by 13mm deep. Alternatively, you can create laminated table using a base and 12.7mm (1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e ) thick material on either side of the track. Securing the track in the groove is easy with pre-drilled, countersunk holes every 270mm.\u003c\/p\u003e\u003cp\u003eThe external measurements overall are 915mm(36\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) long, 31 x 12.7mm deep and the T-slot is 19 x 24 x 9.5mm deep. With its 19mm wide channel, the mitre slot track will work with any standard 19 x 9.5mm (3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) mitre gauge bar with or without a T-facility. Supplied in 915mm lengths, the track is easily cut with a hacksaw to a different size if required.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118257164635,"sku":"103565","price":16.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103565_xl.jpg?v=1789773182","url":"https:\/\/www.axminstertools.com\/products\/ujk-mitre-slot-track","provider":"Axminster Tools","version":"1.0","type":"link"}
