{"product_id":"ujk-multifuction-benchframe-with-sawhorses","title":"UJK MultiFuction Benchframe with Sawhorses","description":"\u003cp\u003eThe UJK Multifunction Workbench Mk II with Sawhorses is a highly adaptable, modular workbench system designed for modern workshops, site work and flexible working environments. Combining the proven Mk II workbench frame with a pair of UJK Sawhorses, this kit delivers a strong, stable and easily portable platform suitable for a wide range of woodworking and making tasks.\u003c\/p\u003e\u003cp\u003eManufactured in Britain, the Multifunction Workbench Mk II frame is built from high‑quality birch plywood, with cross‑grain layers set at right angles to one another for excellent rigidity and long‑term dimensional stability. An 18mm outer frame and 12mm inner frame ensure the structure remains perfectly flat and true. All four sides are finished with the durable Heksa hex‑grip surface, providing excellent grip for clamping along with resistance to moisture, weathering and common workshop chemicals. The front and rear aprons feature 20 x 20mm bench dog holes with an integrated T‑track on both sides, allowing fast, accurate and secure clamping and alignment.\u003c\/p\u003e\u003cp\u003eSupplied with a pair of professional‑grade UJK Sawhorses, this kit offers exceptional strength and versatility with the added benefit of portability. The all‑steel sawhorses fold flat for easy transport and storage, making them ideal for workshops with limited space or for taking to site. Quick‑release setup allows them to be deployed rapidly, while the wide stance and rubber feet provide excellent stability on a variety of surfaces. Telescopic legs offer height adjustment to suit different tasks, and the reinforced top rail is designed to withstand demanding use. Together, the pair provides a very high load capacity, creating a solid and dependable base for the workbench frame. Each sawhorse can support up to 590kg, and together, they boast an impressive, combined capacity of 1,180kg.\u003c\/p\u003e\u003cp\u003eSitting at the heart of the UJK modular system, this setup provides a flexible foundation that can be configured to suit your workspace and the way you work. The workbench frame is designed to sit securely on the sawhorses, forming a rigid and stable working platform. The overall dimensions of the frame are 1,140mm x 750mm x 150mm, and it is certified by the Pan European Forest Council (PEFC), ensuring responsibly sourced materials.\u003c\/p\u003e\u003cp\u003eThis kit includes the Multifunction Workbench Mk II frame and two UJK Sawhorses. The setup is completed by adding a UJK worktop of your choice (102537, 102538 or 109796), or a bespoke top made using the UJK Parf Guide System, allowing you to tailor the system precisely to your needs.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54251278139739,"sku":"721046","price":290.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/721046_xl.jpg?v=1791203541","url":"https:\/\/www.axminstertools.com\/products\/ujk-multifuction-benchframe-with-sawhorses","provider":"Axminster Tools","version":"1.0","type":"link"}
