{"product_id":"ujk-multifunction-benchframe-with-trestles","title":"UJK MultiFunction Benchframe with Trestles","description":"\u003cp\u003eThe UJK Multifunction Workbench Mk II with Telescopic Trestles is a highly adaptable, modular workbench system designed for modern workshops and precision woodworking. Combining the robust Mk II workbench frame with a pair of UJK Telescopic Trestles, this kit delivers a strong, stable and height‑adjustable working platform suitable for a wide range of tasks.\u003c\/p\u003e\u003cp\u003eManufactured in Britain, the Multifunction Workbench Mk II frame is constructed from high‑quality birch plywood, with cross‑grain layers set at right angles to one another for excellent rigidity and long‑term dimensional stability. An 18mm outer frame and 12mm inner frame ensure the structure remains perfectly flat and true. All four sides are finished with the durable Heksa hex‑grip surface, providing excellent grip for clamping along with resistance to moisture, weathering and common workshop chemicals. The front and rear aprons feature 20 x 20mm bench dog holes with an integrated T‑track on both sides, allowing fast, accurate and secure clamping and alignment.\u003c\/p\u003e\u003cp\u003eSupplied with a pair of UJK Telescopic Trestles, this setup offers exceptional strength, precision and flexibility. Manufactured from durable steel for long‑term reliability, each trestle provides excellent rigidity, while the top rails are designed for accurate side clamping. Smooth telescopic height adjustment with a positive locking mechanism allows the working height to be set quickly and securely between 780mm and 1,190mm. Wide footprints with rubber feet ensure superb stability on workshop floors, job sites or outdoor surfaces, and a lower rail on each trestle provides convenient storage for tools and accessories. Each trestle supports loads of up to 200kg, creating a solid and dependable base for the workbench frame.\u003c\/p\u003e\u003cp\u003eSitting at the heart of the UJK modular system, the frame is designed to sit securely on the trestles, forming a rigid and stable working platform that can be configured to suit your space and the way you work. The overall dimensions of the frame are 1,140mm x 750mm x 150mm, and it is certified by the Pan European Forest Council (PEFC), ensuring responsibly sourced materials.\u003c\/p\u003e\u003cp\u003eThis kit includes the Multifunction Workbench Mk II frame and two UJK Telescopic Trestles. The setup is completed by adding a UJK worktop of your choice (102537, 102538 or 109796), or a bespoke top made using the UJK Parf Guide System.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54251287478619,"sku":"721045","price":275.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/721045_xl.jpg?v=1791203645","url":"https:\/\/www.axminstertools.com\/products\/ujk-multifunction-benchframe-with-trestles","provider":"Axminster Tools","version":"1.0","type":"link"}
