{"product_id":"ujk-multifunction-squares-pair","title":"UJK Multifunction Squares - (Pair)","description":"\u003cp\u003eSmall in size but big when it comes to functionality. Supplied as a pair and probably one of the most useful tools of this type.\u003c\/p\u003e\u003cp\u003eThe squares are approximately 90mm on each side (18mm thick) with graduations in both metric and imperial, 0 to 80mm and 0 to 3.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e. Each is provided with a removable steel base, which you can use to register the square against an edge when marking or checking a mitre or square. The steel base is held in place by rare earth magnets set into the sides of the square. The magnets hold the square in place on cast-iron machine tables for setting or checking blades and fences at 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e or 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. The scale along the edge allows you to use the square as a height gauge for saw blades and router cutters.\u003c\/p\u003e\u003cp\u003eYet another function is as assembly squares using a couple of clamps. These squares are perfect for ensuring the joint is at exactly 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e when used on an internal corner. The notches on each side allow the use of UJK Fence Clamps for a neater clamping arrangement. In the centre of each square is a 20mm hole. The hole allows the squares, in conjunction with a 20mm dog, to be used on a multifunction bench as reference or to clamp against.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118434931035,"sku":"107559","price":33.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107559_xl.jpg?v=1789779702","url":"https:\/\/www.axminstertools.com\/products\/ujk-multifunction-squares-pair","provider":"Axminster Tools","version":"1.0","type":"link"}
