Small in size but big when it comes to functionality. Supplied as a pair and probably one of the most useful tools of this type.
The squares are approximately 90mm on each side (18mm thick) with graduations in both metric and imperial, 0 to 80mm and 0 to 3.1/2. Each is provided with a removable steel base, which you can use to register the square against an edge when marking or checking a mitre or square. The steel base is held in place by rare earth magnets set into the sides of the square. The magnets hold the square in place on cast-iron machine tables for setting or checking blades and fences at 90 or 45. The scale along the edge allows you to use the square as a height gauge for saw blades and router cutters.
Yet another function is as assembly squares using a couple of clamps. These squares are perfect for ensuring the joint is at exactly 90 when used on an internal corner. The notches on each side allow the use of UJK Fence Clamps for a neater clamping arrangement. In the centre of each square is a 20mm hole. The hole allows the squares, in conjunction with a 20mm dog, to be used on a multifunction bench as reference or to clamp against.
