These CNC machined, UJK Parf Long Anchor Dogs open up a whole range of new possibilities for benches with thicker tops. These aluminium dogs are 32mm long and are a precise fit in the holes made by the UJK 20mm cutter. They fit exactly into the 20mm holes of the UJK Multifunction Workbench and are compatible with the Festool MFT/3 tabletop and other grid tables with 20mm holes. The hole must be chamfered first which allows the chamfer profile of the dog to sit flush in the bench's top surface.
Once installed the dogs give you an M8 threaded hole in your work top for any number of additional applications.
The UJK Chamfer Ring© is the intellectual property of Axminster Tools Ltd. Any infringement is strictly prohibited.
Made in Britain Yes
Intended Use Used in conjunction with dog holes to hold work to a workbench.
EAN Barcode 5052511123797
