{"product_id":"ujk-parf-mk-ii-guide-system","title":"UJK Parf Mk II Guide System","description":"\u003cp\u003eDo you want to create a custom-made bench top? Or a portable cutting board? Perhaps a replacement MFT top? With the award winning UJK Parf Mk II Guide System, you can do all of this and more. The versatile jig system allows you to make a simple configuration in less than 30 minutes whenever the need arises. It may appear complicated at first sight; in reality, it is quite straightforward with highly accurate results easily achievable.\u003c\/p\u003e\u003cp\u003eBased on Pythagoras' theorem, it guarantees accuracy and eliminates any chance of cumulative error. It helps produce a bench top with a truly accurate pattern of 20mm holes. When used with a set of UJK Super Dogs, a guide rail and a track saw, it guarantees perfect, quick and easy 45° and 90° cuts every time. The UJK Parf Mk II Guide System is an invaluable tool for professional trades and home workshops.\u003c\/p\u003e\u003cp\u003eThe MK II guarantees drilling accuracy overtime. It allows you to create a tighter grid format at 32mm or 48mm spacing giving you more options when cutting, assembling or clamping. It's also supplied with a centrotec bit holder for your 3mm drill bit resulting in easier operation.\u003c\/p\u003e\u003cp\u003eMost importantly accuracy is assured and this jig will not allow for cumulative errors due to the way it works.\u003c\/p\u003e\u003cp\u003eThe design of the UJK Parf Mk II Guide System preserves and guarantees the long-term accuracy of the jig as well as improving the ease of use.\u003c\/p\u003e\u003cp\u003eThe Parf Mk II Guide System uses 2 x Mk II Parf sticks along with a drill guide and a special 3mm drill bit to create rows and columns of holes at perfect right angles.\u003c\/p\u003e\u003cp\u003eThe accuracy of the system is dependent on the very tight tolerance of the holes in the Parf stick. The Mk II drill guides locate positively into holes in the UJK Mk II Parf Stick. The guides feature an oilite bush to guide the Mk II 3mm drill bit. This design prevents any possibility of wear or elongation of these vital holes as a result of repeated use. Additional holes in the Mk II sticks offer the possibility of drilling intermediate holes at 32mm or 48mm centres or holes at predetermined angles other than 90°. The Parf sticks have a metric scale along one edge so that they may have other uses in the workshop.\u003c\/p\u003e\u003cp\u003eOnce the pattern of 3mm holes is complete, use the Parf guide block and 20mm boring bit to enlarge the holes and your bench top is finished and ready to take bench dogs.\u003c\/p\u003e\u003cp\u003eThe complete UJK Parf Mk II Guide System comprises 2 x 1m long Mk II Parf sticks, with holes along their length at 96mm centres; 2 x Mk II drill guides, a Mk II 3mm drill bit and 3 x Mk II guide pins. An extractor outlet, guide block, along with a pair of UJK low profile dogs and a special 20mm TC drill bit with a 3mm centre guide are also included. Please note: 3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e cutter is not available.\u003c\/p\u003e\u003cp\u003eThe UJK Parf Mk II Guide System is a collaboration between Axminster Tools and Peter Parfitt. Manufacturing of the system takes place entirely in Axminster, Devon under the UJK brand name.\u003c\/p\u003e\u003cp\u003eThe UJK Chamfer Ring© is the intellectual property of Axminster Tools Ltd. Any infringement is strictly prohibited.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118306185563,"sku":"104779","price":199.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104779_xl.jpg?v=1789774681","url":"https:\/\/www.axminstertools.com\/products\/ujk-parf-mk-ii-guide-system","provider":"Axminster Tools","version":"1.0","type":"link"}
