UJK
UJK Pencil
SKU: 112998
€13,00
  • Ergonomic grip makes it easy to hold and control
  • Slender tip design is perfect for deep-hole marking
  • Holster with a built-in sharpener and pocket clip
  • Shaped to prevent it from rolling off a bench
  • Eye-catching UJK orange in colour
  • Leads are quick and easy to change
  • Length: 164mm, weight: 23g
The UJK Pencil, is not like standard marking pencils. This innovative pencil comes with a protective holster and a strong pocket clip, ensuring it's always within reach and less likely to get misplaced. Its classic UJK Orange colour and anti-roll shape make it easy to spot and keep in place, even on busy workbenches.
Designed for comfort and precision, the ergonomic grip allows for easy handling and control. The slender tip is perfect for deep-hole marking, while the holster's bottom hole lets dirt and moisture escape, so you can use the marker without removing it. A built-in sharpener under the clip, makes for quick and easy to change leads.
Specifications:
Length: 164mm
Weight: 23g
Web Attribute Set Marking Pencils
EAN Barcode 7317846511793
