{"product_id":"ujk-pocket-hole-drill-bit-complete-package","title":"UJK Pocket Hole Drill Bit Complete Package","description":"\u003cp\u003eIntroducing the UJK Pocket Hole Drill Bit Complete Package – your ultimate solution for precise and efficient pocket hole drilling. This comprehensive package includes the UJK Pocket Hole Drill with a 12mm Bit with drift pin, the UJK Stop Collar for Pocket Hole Drill Bit, and three replacement Drill Tips in sizes 30mm, 22mm, and 12mm. The UJK Pocket Hole Drill is the ideal upgrade for pocket hole drilling.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eUJK Pocket Hole Drill with 12mm Bit\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThe UJK Pocket Hole Drill with 12mm bit is the ideal upgrade for pocket hole drilling. The key feature of the UJK stepped drill bit is its interchangeable pilot drill tips, no need to buy a new drill when the tips snap (as they do), with this drill you can quickly change the pilot drill tips using the included drift pin, unlike standard drills.\u003c\/p\u003e\u003cp\u003eThe replacement drill tips are available in additional lengths of 30mm, 22mm, and 12mm and manufactured from M2 Steel. This versatility allows you to tackle a variety of applications with ease.\u003c\/p\u003e\u003cp\u003eIts unique geometry makes it suitable for wider joints, and the UJK Pocket Hole Drill is built to withstand frequent use, providing a better fit for stronger connections. The parabolic flute design rapidly clears waste from your pocket hole jig and with precision spurs allowing for the cleanest of cuts, ideal for creating the perfect plug. All this combining the benefits of high performance and design for fast, clean results.\u003c\/p\u003e\u003cp\u003eThe UJK Pocket Hole Drill is a testament to high-quality engineering and is designed to deliver precision and durability, making it an essential tool for creating strong, hidden joints. The UJK Pocket Hole Drill is compatible with all makes of pocket hole jigs, including the UJK Pocket Hole Jig, and it is Festool Centrotec compatible, ensuring seamless integration with your existing systems.\u003c\/p\u003e\u003cp\u003eWe strongly encourage the use of dust extraction when using Pocket Hole Jigs and accessories.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eUJK Stop collar for Pocket Hole Drill Bit\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThis split stop collar is designed to fit the shank of the UJK pocket hole drill bit, as well as other drill bits with 9.5mm (3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) shanks. Its one-piece single split design provides greater clamping force compared to a set-screw shaft collar. Unlike a locking grub screw type, a split collar grips the shaft without leaving score marks.\u003c\/p\u003e\u003cp\u003eInternal diameter: 9.5mm, external diameter: 19mm, thickness: 9.5mm.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118529204571,"sku":"111918","price":37.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111918_xl.jpg?v=1789784446","url":"https:\/\/www.axminstertools.com\/products\/ujk-pocket-hole-drill-bit-complete-package","provider":"Axminster Tools","version":"1.0","type":"link"}
