UJK
UJK Pocket Hole Drill Split Stop Collar
SKU: 106482
€1,95
  • Fits the UJK pocket hole drill bit
  • Collar grips without leaving score marks
  • Split collar design ensures secure non-slip grip
  • Simple installation and adjustment
  • Internal diameter 9.5mm
This split stop collar is specifically made to fit the shank of the UJK pocket hole drill bit. Obviously, it will fit other drill bits with 9.5mm (3/8) shanks. The one-piece single split design offers greater clamping force compared to a set-screw shaft collar. Unlike a locking grub screw type, a split collar grips the shaft without leaving score marks.
Internal diameter 9.5mm, external diameter 19mm, thickness 9.5mm.
Web Attribute Set Wood Boring Bits
EAN Barcode 5052511119189
