{"product_id":"ujk-pocket-hole-drill-with-12mm-bit","title":"UJK Pocket Hole Drill with 12mm Bit","description":"\u003cp\u003eThe UJK Pocket Hole Drill with 12mm bit is the ideal upgrade for pocket hole drilling. The key feature of the UJK stepped drill bit is its interchangeable pilot drill tips, no need to buy a new drill when the tips snap (as they do), with this drill you can quickly change the pilot drill tips using the included drift pin, unlike standard drills.\u003c\/p\u003e\u003cp\u003eThe replacement drill tips are available in additional lengths of 30mm, 22mm, and 12mm and manufactured from M2 Steel. This versatility allows you to tackle a variety of applications with ease.\u003c\/p\u003e\u003cp\u003eIts unique geometry makes it suitable for wider joints, and the UJK Pocket Hole Drill is built to withstand frequent use, providing a better fit for stronger connections. The parabolic flute design rapidly clears waste from your pocket hole jig and with precision spurs allowing for the cleanest of cuts, ideal for creating the perfect plug. All this combining the benefits of high performance and design for fast, clean results.\u003c\/p\u003e\u003cp\u003eThe UJK Pocket Hole Drill is a testament to high-quality engineering and is designed to deliver precision and durability, making it an essential tool for creating strong, hidden joints. The UJK Pocket Hole Drill is compatible with all makes of pocket hole jigs, including the UJK Pocket Hole Jig, and it is Festool Centrotec compatible, ensuring seamless integration with your existing systems.\u003c\/p\u003e\u003cp\u003eWe strongly encourage the use of dust extraction when using Pocket Hole Jigs and accessories.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118529040731,"sku":"111917","price":32.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111917_xl.jpg?v=1789784438","url":"https:\/\/www.axminstertools.com\/products\/ujk-pocket-hole-drill-with-12mm-bit","provider":"Axminster Tools","version":"1.0","type":"link"}
