{"product_id":"ujk-pocket-hole-jig-mk-ii-kit","title":"UJK Pocket Hole Jig Mk II Kit","description":"\u003cp\u003eThe UJK Pocket Hole Jig Mk II Kit has everything you need to get started with pocket hole joinery. At its core is the UJK Pocket Hole Jig Mk II; featuring upgraded bushings that make it fully compatible with the superior UJK Pocket Hole Drill with interchangeable pilot tips, delivering fast, accurate and clean drilling. The bushes are manufactured from Aluminium Bronze Alloy, an exceptionally strong and highly resistant to wear and corrosion, offering durability comparable to medium carbon steel.\u003c\/p\u003e\u003cp\u003eThe kit also includes a UJK Portable Plate, UJK Locking C Clamp, fabric storage case and a 500-piece screw selection with five TX20 bits, so you’re ready to start making strong, hidden joints straight out of the box.\u003c\/p\u003e\u003cp\u003ePocket hole joinery is suitable for many applications when needing strong frames and carcases. A strong, hidden joint is produced using a jig and drilling a hole at an angle into one workpiece, then joining it to a second workpiece with a self-tapping screw. Using a self-tapping screws means there is no need to pre-drill the second workpiece. This makes the process much faster and avoids any alignment issues often encountered with traditional methods such as dowels, biscuits or mortice and tenon joints. They also act as a strong, internal clamp eliminating clamping the joint as the glue dries. Saving time and the frustration of clamping, as well as the problems associated with pulling the assembly out of square with clamping pressure.\u003c\/p\u003e\u003cp\u003eUse this kit two ways: as bench mounted or fit the portable plate and use with the clamp so that you take the jig to site.\u003c\/p\u003e\u003cp\u003eThe Pocket Hole Jig Mk II is constructed entirely from metal components to ensure enhanced durability, and can be conveniently mounted on a workbench.  Use for a wide range of material \/ timber thickness 13 - 36mm, clear metric scales allow for ease of use.\u003c\/p\u003e\u003cp\u003eThe innovative UJK Pocket Hole Drill Complete package comes with the jig and three interchangeable pilot tips in 12mm, 22mm, and 30mm. Allow for quick drill changes, and if a drill tip ever snaps, you can simply replace it without buying a new drill. Its advanced design ensures smoother cutting, improved chip clearance and cleaner holes, offering better performance and longer service life.\u003c\/p\u003e\u003cp\u003eSupplied with; UJK Pocket Hole Jig Mk II, UJK Portable Plate, UJK Locking C Clamp, UJK Pocket Hole Drill Complete Package, fabric UJK Storage case,  500 mixed size, course screws in an assorted storage box.  Screw pack contains: 100 - 4.0 x 25mm, 100 - 4.0 x 30mm, 100 - 4.0 x 35mm, 100 - 4.0 x 50mm, 100 - 4.0 x 60mm and 5 - TX20 bits.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54251302551899,"sku":"720996","price":249.78,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/720996_xl.jpg?v=1791203813","url":"https:\/\/www.axminstertools.com\/products\/ujk-pocket-hole-jig-mk-ii-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
