UJK
UJK Pocket Hole Plug Cutter
SKU: 506504
£11.98
£9.98 Excl. VAT
  • Create your own pocket hole plugs
  • Use in a pillar drill or drill stand
  • Cuts 9.5mm (3/8) diameter, plugs 55mm long
  • Maximum speed 700 RPM
Make your own pocket hole plugs. Simply use the plug cutter in a pillar drill to create you own plugs using matching or contrasting timber, glue them in, trim using a flush cut saw and sand to a finish. Cuts 9.5mm (3/8) diameter, plugs 55mm long. Maximum speed 700 RPM.
Web Attribute Set Plug Cutters & Plugs
EAN Barcode 5052511062768
