{"product_id":"ujk-portable-trim-router-table","title":"UJK Portable Trim Router Table","description":"\u003cp\u003eThe UJK Portable Trim Router Table is specifically designed for use with the increasingly popular 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e palm type routers. This table and fence offers you all the accuracy and versatility of a large full size router table, but on a smaller scale; providing a portable, benchtop format.\u003c\/p\u003e\u003cp\u003eThe table top is made from 20mm thick phenolic board, an extremely stable, durable and strong material; perfect for this application (the legs are 16mm phenolic board). The table top is 400mm wide x 300mm.The aperture in the table is 40mm diameter. The top features a machined T-slot for a mitre fence etc. The slot is fully compatible with UJK M6 or M8 T-slot bolts.\u003c\/p\u003e\u003cp\u003eThe 400mm x 55mm tall fence is adjustable front to back. The aperture in the fence is 50mm x 28mm high. The fence also has a machined T-slot for mounting stops etc. The fence includes a safety shield and the extraction outlet has a slight taper, which ensures a good fit for hoses or adaptors from different brands of extractor.\u003c\/p\u003e\u003cp\u003eOn the base; the front rail has three 20mm dog holes for attaching the table to a multifunction workbench using bench dogs. The front rail is designed to allow the use of F or G clamps for attaching the table to a worktop or bench. The back rail features five 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e holes for cutter storage.\u003c\/p\u003e\u003cp\u003eWill my router fit? The criteria being; the router must have a base no larger than 152mm in diameter and be no taller than 250mm. The 152mm recess is cut into the underside of the top to a depth of 10mm, minimising any potential loss of depth of cut. To fit your router, use the router’s base as a template to mark and drill fixing holes. Alternatively photocopy the router base or make a template from thin card. Full details are covered in the instructions.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118484803931,"sku":"109531","price":249.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109531_xl.jpg?v=1789782078","url":"https:\/\/www.axminstertools.com\/products\/ujk-portable-trim-router-table","provider":"Axminster Tools","version":"1.0","type":"link"}
