Produced to accompany the UJK drill guide, these UJK precision angle stops are specifically designed to allow you to set precise angles for your drilling tasks, offering increased control and repeat accuracy in your work. These angle stops will allow you to work more efficiently by eliminating the need for manual measurements and guesswork. This reduces errors and wasted materials, ultimately saving you time and effort. The precision angle stops are machined to ensure that an accurate 90 drilling position is achieved. They can also be adjusted to enable a precise, repeat stop at any angle and can be fitted on both sides of the quadrant.
Web Attribute Set Drilling Guides
EAN Barcode 5052511132904
