UJK
UJK R/H Self Adhesive Steel Tape 3m Metric
SKU: 105389
£7.28
£6.07 Excl. VAT
  • Self adhesive tape with metric scales
  • 13mm wide flexible material for easy application
  • Supplied as one complete tape from zero to 3m
  • Scales read in cm with mm divisions
  • Tape reads from left to right
  • Accuracy is +/-0.25mm per 600mm
A right handed self adhesive measuring tape with metric scales. The tape is 13mm wide and comes as one complete tape, measuring from zero to 3m. It is easy to set up with the scales reading in centimetres with millimetre divisions.
Be sure to choose the correct tape orientation: the R/H tape reads from left to right to fit on the right side of your saw blade etc. A left handed option is available.
Please note, these tapes are a flexible material, the expected accuracy is +/-0.25mm per 600mm.
Web Attribute Set Self Adhesive Scales
EAN Barcode 5052511108862
