{"product_id":"ujk-rail-clamp-mft-top","title":"UJK Rail Clamp MFT Top","description":"\u003cp\u003eThe UJK Rail Clamp MFT Top will advance your busy workshop with more convenience, added precision to our woodworking projects, and unmatched versatility.\u003c\/p\u003e\u003cp\u003eProudly made in the UK, the UJK Rail Clamp MFT Top seamlessly combines the accuracy of an MFT top with innovative T-Slots, increasing your clamping capabilities.\u003c\/p\u003e\u003cp\u003eUnlock the freedom to position your clamps anywhere along the track, securing them effortlessly with just one hand while you can continue to work with the other. Unlike standard MFT tops with fixed intervals – our bench top allows you to tailor your clamps for each project. The inclusion of T-Slots ensures compatibility with a range of clamps designed for track saws and perfectly fits the Festool MFT table. Slide your clamps into the CNC machined track with unparalleled ease as you position and lock them securely into place for a seamless workflow.\u003c\/p\u003e\u003cp\u003eThe UJK Rail Clamp MFT Top is engineered with chamfered holes as standard for added precision, a hallmark of UJK workbenches. This design element ensures tight tolerances, delivering square and firm assembly with every use. Crafted from high-quality birch ply, this bench top is not only robust but also showcases the exceptional craftsmanship synonymous with UK manufacturing.\u003c\/p\u003e\u003cp\u003eOverall Size:1,102 X 718mm\u003c\/p\u003e\u003cp\u003eNote: Sag of the table can happen, to avoid this, screw two batons across the width to ensure the table is flat.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118496895323,"sku":"109796","price":293.78,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109796_xl.jpg?v=1789782691","url":"https:\/\/www.axminstertools.com\/products\/ujk-rail-clamp-mft-top","provider":"Axminster Tools","version":"1.0","type":"link"}
