{"product_id":"ujk-ratchet-hold-down-clamp","title":"UJK Ratchet Hold Down Clamp","description":"\u003cp\u003eThe spigot on this fast acting ratchet hold down fits perfectly into any 20mm bench dog hole. The unique design makes it perfect for use with a UJK Multifunction workbench or the Festool MFT\/3 Multifunction table. Additionally, you can use it on any UJK Parf Guide system cutting table and any Axminster woodworking bench. The maximum bench top thickness is 30mm.\u003c\/p\u003e\u003cp\u003eThe hold down utilises the rapid action and controllable high clamping power of the Forged Quick Lever Clamp. It has a throat depth of 60mm and a maximum working height of 90mm. The spigot mount, locking knob and square support plates are S303 stainless steel CNC machined, highly accurate and rust free.\u003c\/p\u003e\u003cp\u003eThe ratchet mechanism can generate exceptionally high clamping force; the support plates spread the load, preventing the spigot from deforming the dog hole. Dog holes and those in the Festool MFT\/3 rely on their exact sizing to maintain accuracy, whenever feasible; it is advisable to the support plates.\u003c\/p\u003e\u003cp\u003eThe top 4mm of the spigot is 25mm diameter, without a support plate this sits directly on top of you bench and precisely matches the 25mm portion of Bench dogs. It allows you to use the clamp’s spigot as a reference, positioning and clamping a workpiece at the same time. The ratchet mechanism gives you control over the amount of pressure applied without fear of damaging the dog hole.\u003c\/p\u003e\u003cp\u003eWhen positioning a workpiece on the vertical face of a UJK workbench. A  Twist or Bench dog in one hole and this ratchet clamp directly above, means you will have the work set up in a matter of seconds.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118277284187,"sku":"103566","price":61.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/103566_xl.jpg?v=1789773281","url":"https:\/\/www.axminstertools.com\/products\/ujk-ratchet-hold-down-clamp","provider":"Axminster Tools","version":"1.0","type":"link"}
