{"product_id":"ujk-router-lift-complete-package-mkii","title":"UJK Router Lift Complete Package MKII","description":"\u003cp\u003eThe UJK Router Lift Complete Package MKII is a comprehensive, precision-engineered solution designed to bring accuracy, control and efficiency to your routing setup. Combining the UJK Router Lift with the powerful UJK Motor and Mount, this fully integrated system delivers smooth performance and long-term stability for demanding workshop use. The lift mechanism allows for precise, micro-adjustable height changes from above the table, making it quick and easy to set cutting depth or change router cutters without removing the motor.\u003c\/p\u003e\u003cp\u003eAt the heart of the system is a robust 1800W motor featuring variable speed control from 10,000 to 22,000 RPM, providing the versatility needed to handle a wide range of routing applications and materials. The soft-start function ensures controlled start-up, while constant speed electronics maintain consistent performance under load for clean, accurate results. Premium sealed shaft bearings help minimise bit run-out, improving overall cutting precision and finish quality. The updated design places the variable speed control directly on the switch box for easy access, allowing fast, convenient adjustments without reaching beneath the table. For added flexibility, the control box can be positioned wherever best suits your workshop layout.\u003c\/p\u003e\u003cp\u003eDesigned to fit UJK router tables and compatible with most router table setups (305 x 229 x 6mm), this complete package provides a reliable, workshop-ready solution straight out of the box. The kit includes the UJK Variable Speed Motor for Router Lift (230V), UJK Motor Mount for Router Lift and UJK Router Lift, along with 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, 1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, 8mm and 12mm ER collets, plus both UK and EU plugs for added versatility.\u003c\/p\u003e\u003cp\u003eIncludes UJK Variable Speed Motor (SKU 114370), UJK Motor Mount (SKU 113004) and UJK Router Lift (SKU 502701)\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54251322442075,"sku":"721048","price":789.96,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/721048_xl.jpg?v=1791204043","url":"https:\/\/www.axminstertools.com\/products\/ujk-router-lift-complete-package-mkii","provider":"Axminster Tools","version":"1.0","type":"link"}
