{"product_id":"ujk-self-adjusting-toggle-clamp-50-dog","title":"UJK Self Adjusting Toggle Clamp 50 \u0026 Dog","description":"\u003cp\u003eThe UJK Self Adjusting Toggle Clamp 50 is available in a package with a M8 UJK Parf Anchor Dogs and M8  T-Slot Bolt, allowing you to utilise the strength of the clamps with a MFT style bench.\u003c\/p\u003e\u003cp\u003eSimply fit the anchor dog into the 20mm workbench hole, attach the UJK Self Adjusting Toggle Clamp to the UJK Anchor Dog with an M8 T Slot Bolt for the ultimate strength and accessibility for your clamping needs.\u003c\/p\u003e\u003cp\u003eIndustrial quality toggle clamps are invaluable when constructing a custom-made jig for use on a router table, spindle moulder or saw bench.\u003c\/p\u003e\u003cp\u003ePress the handle down and the clamp locks in position securely holding the workpiece in place. Toggle clamps are quick to lock and unlock and are very versatile. Anywhere you need a fast, firm hold-down, a toggle clamp is useful. They are perfectly suited for use in small-scale production situations.\u003c\/p\u003e\u003cp\u003eThis self-adjusting toggle clamp automatically adjusts to the height of the workpiece within its capacity. A set-screw, on the cantilevered joint, adjusts the clamping force to your particular needs, up to 2,000N. The wide injection moulded handle has a soft grip insert, which makes setting the clamp a comfortable operation. Made from quality steel, galvanised and passivated against corrosion; the maximum reach is 60mm and maximum workpiece thickness approximately 50mm.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118528680283,"sku":"111905","price":31.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111905_xl.jpg?v=1789784413","url":"https:\/\/www.axminstertools.com\/products\/ujk-self-adjusting-toggle-clamp-50-dog","provider":"Axminster Tools","version":"1.0","type":"link"}
