{"product_id":"ujk-self-adjusting-toggle-clamp-push-pull-25-dog","title":"UJK Self Adjusting Toggle Clamp Push\/Pull 25 \u0026 Dog","description":"\u003cp\u003eThe UJK Self Adjusting Toggle Clamp Push\/Pull 25 is available in a package with a M8 UJK Parf Anchor Dogs and M8  T-Slot Bolt, allowing you to utilise the strength of the clamps with a MFT style bench.\u003c\/p\u003e\u003cp\u003eSimply fit the anchor dog into the 20mm workbench hole, attach the UJK Self Adjusting Toggle Clamp to the UJK Anchor Dog with an M8 T Slot Bolt for the ultimate strength and accessibility for your clamping needs.\u003c\/p\u003e\u003cp\u003eIndustrial quality self-adjusting push\/pull toggle clamp converts the movement of the handle into an axial movement of the piston. The piston pushes a workpiece against a fence or stops and locks with the handle in the horizontal position. For example as used on most pocket-hole jig systems. The piston has 25mm of travel and automatically adjusts to variations in workpiece thickness. The piston centre height is 23mm. A set-screw, on the cantilevered joint, adjusts the clamping force to your particular needs up to 3,000N.\u003c\/p\u003e\u003cp\u003eThe piston has an internal thread with an extension for manual length adjustment. The wide injection moulded handle has a soft grip insert, which makes setting the clamp a comfortable operation. Made from quality steel, galvanised and passivated against corrosion.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118528844123,"sku":"111906","price":31.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111906_xl.jpg?v=1789784421","url":"https:\/\/www.axminstertools.com\/products\/ujk-self-adjusting-toggle-clamp-push-pull-25-dog","provider":"Axminster Tools","version":"1.0","type":"link"}
