{"product_id":"ujk-self-adjusting-toggle-clamp-push-pull-25","title":"UJK Self Adjusting Toggle Clamp Push\/Pull 25","description":"\u003cp\u003eIndustrial quality self-adjusting push\/pull toggle clamp converts the movement of the handle into an axial movement of the piston. The piston pushes a workpiece against a fence or stops and locks with the handle in the horizontal position. For example as used on most pocket-hole jig systems. The piston has 25mm of travel and automatically adjusts to variations in workpiece thickness. The piston centre height is 23mm. A set-screw, on the cantilevered joint, adjusts the clamping force to your particular needs up to 3,000N.\u003c\/p\u003e\u003cp\u003eThe piston has an internal thread with an extension for manual length adjustment. The wide injection moulded handle has a soft grip insert, which makes setting the clamp a comfortable operation. Made from quality steel, galvanised and passivated against corrosion.\u003c\/p\u003e\u003cp\u003eIt has a central hole to allow fitting to MFT using UJK anchor dogs. Dogs and toggle clamp plates available to attached the clamp to a Multifunction work bench where needed (sold separately).\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118500827483,"sku":"109992","price":19.78,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109992_xl.jpg?v=1789783046","url":"https:\/\/www.axminstertools.com\/products\/ujk-self-adjusting-toggle-clamp-push-pull-25","provider":"Axminster Tools","version":"1.0","type":"link"}
