The standard central insert supplied with the router elevator and other UJK router table insert plates has a 38mm diameter central hole. We are now able to offer a Phenolic replacement for this plus some alternative sizes so that the space between the cutter being used and the edge of the insert can be kept as close as possible. Another option is a guide bush adaptor to enable the fitting of American/Leigh style threaded guide bushes. The steppe
EAN Barcode 5052511075409
